Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
Question Closed
Grey wifi, won't charge, tried battery... what else?
Hi! I've got an iphone 4s that had a minor water incident. It wouldn't turn on, I took the back off and dried it as well as I could. It was only wet near the top. I left it for a day in rice (amateur move, I know now.) and then I charged it. It seemed to work fine, except for getting a teeny bit hot. Then about three days later, it broke completely. The wifi button was grey, it was constantly "searching," (I don't have a mobile plan) and it would only light up or do anything at all if the charger is plugged in. When the charger is plugged in, it says 100% battery. But as soon as I unplug it, it gave me a black screen. I bought a new battery, replaced it, and immediately I had a working iphone again!
Everything was back to normal. It was still a little bit hot, just a little, but I thought maybe I had incorrectly "Seated" the battery. (I couldn't figure out the corrrect way that the cable was supposed to sit when I put the battery in.) I used it for 2 days, glad it had been such an easy fix. I charged it once in that time. However, last night I let the battery run down to 1% and it powered down. When I went to charge it this morning, it's doing the same things it did before I changed the battery! Oh noes!
I'm willing to replace some parts, but honestly, I don't sauter... Is that the word? I only know screwdrivers and spludgers. Does anyone have any hope or knowledge of what I need to do to this bad boy?
Thanks so much.
Add a comment
1 Answer
Try replacing the battery again, when it turns on test the rear facing camera to see if it works, if not then replace the camera as well and that should solve your heating issue. As far as the wifi there is a trick that you need to heat up a particular chip and it will start working again.
1 Comment:
Okay I'm replacing the battery again, but as far as I remember, the rear camera is still fine.
Actually, when I put a new battery in, the wifi was just fine. So at this point when the new battery comes, I think I'm just going to try to figure out which part is getting hot and shorting out the batteries.
Thanks.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 321
