Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Questions View all
Question Closed
My MacBook Pro 13" won't turn on
Hi I have a mid 2009 13.3" 2.26GHz MacBook Pro I was removing the battery to get to the magic pad to clean the edges so it would click, I frequently replugged the battery in to double check it was still working which it was, however I wasn't wearing any anti static guard and was forced to pick it up and move it without thinking I must have touched the logic board assumingly, because now it won't turn on at all, battery life side button displays zero light the MagSafe charger displays a small green light if any and the macbook doesn't turn on without the battery in either, I'd greatly appreciate any help
Hopefully not a logic board problem
Add a comment
1 Answer
Chosen Solution
Leave it unplugged overnight - with the battery disconnected then try a boot Restart (Control-Command-Power buttons at the same time) with just the ac adaptor reconnected.
The computer should boot if undamaged... it will run a bit slower without the battery. If it fails to start you've probably shorted out the logic board.
If this answer is acceptable please remember to return and mark it.
3 Comments:
Ok thank you I'll try that tonight and I'll let you know how it goes
by
Didn't work :/
by
Then it would appear to me you shorted out your logic board. Either part out the machine or replace the logic board. Mind your ESD procedures.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,645
