Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Questions View all
Question Closed
Black screen after battery and screen replaced?
Water damaged I pod touch 4th gen,I've replaced the battery and screen,iTunes recognizes the i touch but screen still will not come on. I've tried shorting the battery(and heard the "peep",like when you connect your i touch to a charging cord) and I can see all the contents of the i touch on iTunes. The screen is good,I tried it on another 4th gen i touch before installing it. I've cleaned the connectors and tried re-connecting several times,tried letting the battery go dead and then re-charging to see the screen(this worked for another i touch screen I replaced). I'm not sure what part to replace on the logic board for water damage. I've also cleaned the logic board thoroughly with isopropyl.
Add a comment
1 Answer
You are already tried everything that can be recommended and if the battery and screen both are working fine on other iTouch then seems like there problem is only with motherboard. I shall recommend you to check the display connectors with some magnifying glass to make sure that each bit is properly connected. Just in case you can it take it to some hardware shop for a last try or otherwise you may have to replace the logic board.
Add a comment
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 88
