A phablet style smartphone with stylus, released by Micromax Mobile in 2013.
17 Questions View all
Micromax Canvas doodle 2 not getin switched on..? HELP..!
Oh god am so stressed ..my smart phone Micromax canvas doodle 2 which is just 25 days old (bought it 25 days back) was working just fine then i look away for a minute and it did not start at all,cant charge,nothing!even the light that indicates its charging is not seen ..am pretty sure its not the battery because
a moment before i plugged off the charger coz battery was full..i really dont know what to do....will i get a replacement from company???plz help me......please anyone who can help me you'd be saving my life..anyone..please......
Score 29
25 Comments
yes,the same problem occured with me on my new canvas doodle 2 . please can anybody help
by
same error with my phone
by
same error wd mahh phon
by
tysmmmit reallly worked for me guyss another thing you have to hold it for 2 3 mins n it gets startd
jusst have some patience
n dunn panic
by
by
Show 20 more comments
Add a comment
Most Helpful Answer
the best thing is that restart ur phone with (lower volume key + power bottun) and ur phone will be restart...
Score 6
17 Comments:
thank you ... it worked ... thank u
by
Guys thanks a lot, even my phone had a same issue. Cheers.
by
Somebody plz help me..my mobile is canvas hd and is not switching on, got stuck on screen logo.
its been 30 hours. EVEN i tried power key + lower volume button but it is showing Recovery mode and factory mode. I done everything but still got stuck with the same.
plz tell me what to do ?
Plz help .....m in Australia..very hard to get care centre for me....
Megha
by
Thank u.. it is working now....
by
i need someone to help me my macromax canvas a121 is off and is not on pls someone should help me
by
Show 12 more comments
Add a comment
press volume + key and hold for 30 to 35 sec then i will switched on dont worry...
Score 1
Add a comment
The same thing happened with me on micromax doodle2 ..... the fault is of the mother board , the mother board has malfunctioned due to some corrept file downloaded! Go to the nearest service center and tell them the problem !
Add a comment
contact on the number provided in the box of doodle 2.
or try this...
press the volume key (lower volume key) and the power button at same time..
the phn will restart..
this may work...
Add a comment
lower vol key + power on button, keep pressed for some time, it RESTARTS.
If it doesn't work for the first time, try again it worked on the second time for me.
STUPID PHONE. very unreliable. Just GIVES UP ON YOU and at the WORST TIMES !!!
I wish I had bought a SAMSUNG GRAND.
Too Late Now. Spilt Milk.
Add a comment
Go to setting-> Factory data reset
you have an option of back up data as well as autoomatic restore while reinstalling.
Depends on ur requirement check uncheck these and click factory data reset
Add a comment
Worked for me as well. Keep -vol & power buttons pressed simultaneously for some time. I had to press almost 15-20 seconds before the screen appeared. Thanks.
2 Comments:
After pressing lower vol key and power buttons it shows recovery mode : volume up and factory mode : volume down. But after pressing volume down key its not starting up, should I press power button as well or only volume key for factory mode ?
by
same problem with me too.. I have tried everything but nothing seems to work for me ..help somebody...
by
Add a comment
Micromax Canvas Q391 is not working
1 Comment:
Is emergency my phone
by
Add a comment
Add your answer
Nishant will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 14
All Time: 73,646
