Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
DARK (on 2 brand new) screen on iPhone 4!
Hello,
I've just replaced my cracked IPhone 4 screen.
I tried with 2 brand new screen and I obtain a dark screen with each of them.
When I put the old one back, it works but with 2 brand new one ... nothing.
I tried to plug the IPhone into a computer --> nothing, into a wall plug --> nothing.
I tried to reset the phone --> no reaction !
I really wonder why it doesn't work with 2 brand new screens .....
Any help ?
Score -1
3 Comments
thank you for your answer. I ordered the screens from http://www.piece-mobile.com/fr/. I installed the first one completly (withs the screws) and the second one partialy (with the opened phone). So i'm sure the cables are not pinched. I don't understand why it doesn't work ... Is it possible to confuse a 4 & 4S screen ? Best regards
by
Hello,
After investigating, I tested the 2 brand new screens on another IPHONE 4 (with cruciform screws) and both works.
The screens works in a "cruciform" IPhone 4 and don't in a pentalob Iphone 4.
What's the problem ?
Best regards
by
The iPhone 4 and iPhone 4S screens are different. If you have a 4S, you need to make sure that you have a screen that is made for the 4S.
by
Add a comment
Chosen Solution
Sounds to me like you have a different model of iPhone not compatible with that screen, there are several models make sure you go to the settings> about> scroll down to model, order using that model number, and follow the ifix guide for your model of phone while doing the work so you don't make an error
Score 2
Add a comment
I've had this problem on one iPhone 4..refused to take new screen. Old screen worked fine and new screen worked in another broken iPhone. I did all that you have done and the only fix was a new screen from another company, I can only assume that there is some "version" of screen that will only work with a certain iPhone...just like the battery problem in the iPhone 3GS causing reboot loop, and some other mobile phones that have 3 versions of the same phone, I'm guessing that these phones are a release date that only matches the same release screen??
Score 2
Add a comment
Where did you order the screens from? There is a always the possibility to get a bad screen, I have gotten 3 bad ones in one box before, but your problem sounds like there is something else that you are doing wrong. Did you make sure NOT to pinch the LCD cables on each of the new screens. When you bring the cables from the front of the phone through the mid-plane assemble, it is easy to pinch them. Sometimes when this happens, you can break the cable internally, without seeing it. Most iPhone screens don't come with the cables prefolded, so the reason your original screen still works is most likely since the cable stayed folded at the perfect angle once you took them out. Before you push the glass onto the front, be sure to check the LCD and digitiser cables to avoid pinching them. Make sure they are completely through the housing. Examine the new screen's LCD and digitiser cables and see if you can spot any obvious damage.
Hope this Helps
Score 1
Add a comment
Add your answer
fred will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 280
