Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Small metal ring dropped from logic board.
While following the guide to replace the earpiece speaker, step 19, removing the logic board, a tiny silver ring dropped from somewhere (see image). Have no idea where this goes. Put the phone back together without it. Phone is working well. Should I worry about this ring?
Score -1
Add a comment
1 Answer
Chosen Solution
This is the screw threads piece of the lowest screw on the so called WiFi Plate, plate that covers many connectors at top of iPhone. It is not a necessary part. It is held in place by the Y shaped metal piece and the screw. When you removed the screw it slipped out of place.
The location for this part is below the yellow circled screw:
http://d3nevzfk7ii3be.cloudfront.net/igi...
1 Comment:
Oh how interesting! When I first went through the steps to tear down my iPhone and got to that screw, I wasn't able to unscrew it. It was turning but wouldn't come up, had to take a flat driver and push it under the screw head to remove it. When I put the screw back in, all I had to do was to "drop" it in its hole, no screwing needed. Now it makes sense.
Should I worry that this screw might come out of its hole by itself, or is the free space small enough that it will stay in place?
by
Add a comment
Add your answer
Sccoaire will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 283
