Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
52 Questions View all
Why wont my Ipad hold a charge for more than 8 hours?
The Ipad was dropped on the bottom left corner and spider-ed the screen. Also the aluminum backing was damaged and needed to be bent out a little on the corner to help the new glass fix. When I had the screen replaced, everything works perfect except that the battery will not hold a charge more than 8 hours while not being used. When being used, it will last only about 4 hours. I returned it to the person who fixed it and he said everything was "normal".
Add a comment
Chosen Solution
Reduce the brightness, turn off cellular data and keep testing. If the battery still runs out fast, restore the system software and try again
Score 1
Add a comment
or maybe just coincidence and needs a new battery.
Add a comment
Add your answer
Andrew will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 7
All Time: 994
