Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2397 Questions View all
phone wet, USB not connecting. appears broken. Can I replace?
My Iphone recently got wet. Not submerged, just damp from a sweating water cup. The USB connect visually appears damaged, charging wire has black on it as though it may have "short circuited" at same location of damage on Iphone side. SOund is gone too. Should I replace only the USB connection, or also the speaker? Thanks
Score -1
Add a comment
1 Answer
Chosen Solution
Amanda, at this time, I would only replace the dock connector. Follow this guide for that. the part is available right here. While you do that, also clean your logic board with some 90%+ isopropyl alcohol to displace any other liquid. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
Amanda will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 62
