The Samsung Galaxy Tab 2 10.1 is a 10.1-inch Android-based tablet computer and belongs to the second generation of the Samsung Galaxy Tab series.
133 Questions View all
What does a yellow battery charge icon on samsung tablet 2 mean?
I used to have a green battery charge icon when charging. I hadred X when I used the wrong plug before . But now with the right plug I still have a yellow battery charge when charging. It charges fine but what is the reason for the yellow icon?
Score 1
3 Comments
I'm having the same problem. This started happening a couple months after I got the Tab.
by
1/4/2019
This is not an April fool joke same thing started to happen on my tablet about a month ago very annoying. It does charge but takes 12 hours to fully charge not good. Just tried the toothbrush suggestion but no joy! Anyone got any ideas maybe Samsung could offer a solution?
by
How can it be fixed to charge quicker.
by
Add a comment
Chosen Solution
It means it isn't getting full power usually from not using the proper USB wall plug (tablets require 2 amp chargers) basically it means when the screen is on it isn't charging, it will charge with the screen off (at least mine does) but slower than normal, with the screen on it wont lose charge but wont gain either (again this is the case with mine anyway)
Score 3
1 Comment:
I had the same problem but tried a different cable and block and the yellow triangle did not appear During Charging
by
Add a comment
mine wasnt properly making a connection properly at the posts or ur battery is to checck the center post particulally
Add a comment
I had this problem.
I cleaned the battery connections with a dry toothbrush.
Thew same with the USB port on the phone.
All now works well.
Add a comment
i have a yellow caution triangle with an exclamation mark inside it when I plug my phone in when its shut off and its charging really slow. how do I fix this? there is no moisture detected. the battery is not removable. I have a samsung A10e
1 Comment:
A also have same issue in my j6plus mobile battery is not removable and there was no problem with charge pin I have use the original charger but this triangle mark is showing when I shutdown the mobile slopw charging. It has
taking 5 to 6 hours to full charge?
by
Add a comment
Add your answer
Lee will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 24
Past 30 Days: 108
All Time: 56,640
