Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 Questions View all
Display won't turn on after trackpad repairs
Initially the trackpad on this mac wouldn't pop up after being clicked. I used the repair guide for the replacing the trackpad and was able to easily repair it.
After putting everything back in place, I started up the machine. It sounded like everything powered ok, but the display remained dark. When I plug the computer into an external display everything seems to be fine (including the trackpad) but the internal display stays dark.
I have already tried a few things that others have used to fix similar problems including resetting the NRAM and the SMC. I have also taken the mac apart and put it back together again just to make sure I didn't forget to plug in a cable. No dice.
The mac doesn't have a warranty, so my question is, is there anything I can do to A: fix it without buying any parts, or B: fix it by buying an inexpensive part?
Thank you for your help!
Score 1
Add a comment
1 Answer
Chosen Solution
Only you know if you damaged a connector on the logic board... if you did there's little "inexpensive" that can be done.
You could replace the display data cable - that is inexpensive (however that is avery advanced DIY repair). Next comes LED controller, then the screen itself.
If this Answer is helpful please remember to return and mark it Accepted.
Score 2
Add a comment
Add your answer
feanor93 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 238
