Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2376 Questions View all
out of no where it wont charge.
Hello, Ive had my iPhone 4 for 6 months and out of no where it wont charge. Ive charged several things (reboot etc) and it still wont charge nor will the charging icon show when plugged in, why? Nothing happened over night. Im at a loss
Score -1
Add a comment
1 Answer
Chosen Solution
Troy, try a different charging cable as well as a different USB port. Also, try an AC adapter and see what happens. Clean your dock connector with some isopropyl alcohol and a few puffs of compressed air. If that does not change anything, replace the battery and see if that works. If it does not, you may have issues with the charging coil or IC on the logicboard. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
Troy will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 70
