Toshiba’s Equium A210 laptop is a business-oriented version of the Satellite Pro A210 and Satellite A210 laptops.
3 Questions View all
Question Closed
Why does my laptop freeze?
Why does my laptop freeze, then blankout the screen.No response from anything.Press & hold the power button to reset, then reboot.2 or 3 times a day.
Bobby
Add a comment
Most Helpful Answer
The #1 reason for "freezing" is CPU lockup, usually from heat. Dust can collect around the heatsinks and fan, limiting heat dissipation.
Score 3
Add a comment
Have a hardware repair service replace NEC / TOKIN 0E128 OE128 capacitors as stated in:
http://www.docstoc.com/docs/79472760/NEC...
This has solved the problem with already two Toshiba laptops.
Score 3
Add a comment
Check your power settings - Some computers do not like to be put on stand-bye. Does it happen while you are working? What are the specs of your system?
Score 1
Add a comment
well sometimes u can try getting your penis and sticking it up your dads *@!, it sometimes works
Add a comment
scroo you
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 2,970
