Model A1225 / Early 2009 / 2.66, 2.93, or 3.06 GHz Core 2 Duo processor
164 Questions View all
My iMac does not start up, LED#1 not on
all the sudden my iMAc did show no reaction at all. No reaction to the pressing of the power on botton. No noise etc.
I brought my iMac for diagnostic to an authorized Apple dealer/repair center for diagnosis. Their result was that the logic board needs to be replaced. I ordered a used and tested logic board for my iMac model.
After replacing the logic board still the same symptoms. I checked the LEDs. Even #1 does not light up. Unfortunately I trusted the diagnosis of the apple center and did not check the LEDs with my old logic board.
my questions:
1.) Could be even the replacement logic board be defect? Would need to have the similar defect..
2.) Is it the PSU? Is it worth to go down that route as LED#1 does not light up
3.) Is there anything else than the PSU which could cause this, except for the replacement logic board having the same defect
thanks for your help Axel
Score -1
Add a comment
1 Answer
Chosen Solution
Answer #1 Yes - unknown - you didn't check the LEDs before so any answer would be speculation.
Answer #2 This seems to be your problem now - we have to start someplace.
LED Startup Sequence
LED #1 = Power available.
If no LED is visible:
• Verify AC source
• Verify known-good AC cable is connected
• Verify cable connection between AC inlet and power supply
• Verify cable connection between power supply and logic board
• Verify power supply
Answer #3 - reread Answer #2.
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
Add a comment
Add your answer
Axel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 300
