Repair guides, support, and troubleshooting information for MacBook Air models with 13-inch displays.
3664 Questions View all
Question Closed
Will low res screen work in A1379 MacBook air 13 inch?
Macbook air model A1379 is broken. I'm looking for the least expensive way to replace this. I've heard this model has a high resolution screen. Will a low res screen work if it's cheaper?
1 Comment
What are the last three digits of your serial number. This will help to identify your logic board and might shed more light on the pinout. Should your MBA not be a A1369? I think A1379 is the superdrive....
by
Add a comment
1 Answer
Chosen Solution
Jacob Irish, that depends on the panel itself. Check the datasheet wiring diagram, if those match between you current panel and the replacement, it will.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 199
