Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 Questions View all
replaced front panel, after put together picture all haywire
to put a more accurate description after I tried fixing a cracked screen on an iphone 4 for Verizon - the screen is all messed up. theres faded lines faded color you can read anything. I should also add that during installation I accidentally ripped the digitizer cord could this be the problem? thanks!
Score -1
Add a comment
1 Answer
Chosen Solution
David, "ripped the digitizer cord" is possibly causing your issues. Make sure that the LCD connector is properly seated and that you do not have any bend pins or debris in the connector. If all of that looks okay, it is possible that you received a bad display. Try again, a bit more careful, with a new display.
Score 1
Add a comment
Add your answer
[deleted] will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 3
All Time: 86
