2.26 or 2.4 GHz / White plastic unibody enclosure
645 Questions View all
Keyboard ZIF Connector Pinout
I'm looking to determine which contact on the keyboard connection on the A1342 is for the 'on' switch function (or any other contacts on the logic board will do). I'm fairly certain this pin is active low (pressed goes to ground), yes?
Thanks, Keith
Score 1
1 Comment
Hi,
I am searching for the pinout of 34 pin ffc cable of laptop keyboard.
Thanks & Regards,
Yash Kishore
by
Add a comment
Chosen Solution
Keith55555, looks like pin 5 is the one you are looking for. Hope this helps, good luck.
Score 4
3 Comments:
Looks good O.T. Appreciate it. -Keith
by
Anytime ;-) Thanks for accepting my answer.
by
Do you have a keyboard pin out from an A1502?
by
Add a comment
It boggles my mind that this little picture was so hard to find on the INTERNET it is almost like these companies making laptop er um notebooks these days dont want us knowing how they work or operate.
That way we cannot ever comprehend enough to troubleshoot or fix them when something goes wrong. Or they just dont want us realizing that they are built to fail in so many hours. Grrrrrr
Add a comment
I measured the resistance in Ohm of those pins to ground, both keyboard plugged in and (plugged out)
  1. 336 Ω (336 Ω)
  2. 336 Ω (336 Ω)
  3. 337 Ω (336 Ω)
  4. 209 Ω (208 Ω)
  5. 1745 Ω (1745 Ω)
  6. 444 Ω (1.9 MΩ)
  7. 368 Ω (468 Ω)
  8. 365 Ω (1.92 MΩ)
  9. 440 Ω (439 Ω)
  10. 372 Ω (371 Ω)
  11. 369 Ω (369 Ω)
  12. 381 Ω (381 Ω)
  13. 282 Ω (444 Ω)
  14. 477 Ω (477 Ω)
  15. 443 Ω (442 Ω)
  16. 442 Ω (441 Ω)
  17. 442 Ω(441 Ω)
  18. 444 Ω (443 Ω)
  19. 381 Ω (381 Ω)
  20. 441 Ω (440 Ω)
  21. 440 Ω (440 Ω)
  22. 445 Ω (445 Ω)
  23. 442 Ω (441Ω)
  24. 443 Ω (442 Ω)
  25. 440 Ω (440 Ω)
  26. 448 Ω (448 Ω)
  27. 444 Ω (443 Ω)
  28. 444 Ω (444 Ω)
  29. 0 Ω (0 Ω)
  30. 230 Ω (229 Ω)
measured on an MacBook Pro A1502
Add a comment
Add your answer
Keith55555 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 59
All Time: 5,962
