The G4 Quicksilver came in 533MHz, 667MHz, 733MHz, 800MHz, 933MHz, And 1.0GHz speeds.
49 Questions View all
How to test my Logicboard, to check if it works?
Heya,
awesome page!!
But there's one problem, I got a G4 Logicboard, but i cant difference from other G4 Logicboards, so I dont know, if it's a "Quicksilver" etc.
How can i notice, which one it is?
So there's the problem:
I wanna test my Logicboard, but I dont know how I can test it without a PowerMac case!
(Cause of the start up button canles)
Please write back guys!!
greetings,
steve
Score 1
3 Comments
To tell which logic board it is, you can just check the color for a decent comparison. If it's navy blue, it's from a PowerMac G4 MDD (The Last Generation Of PowerMac G4) or an Xserve G4. If it is green, it's from a Quicksilver, or the origional PowerMac G4. Can you find a date on the board?
by
Could you post a picture of the board?
by
_________________________________________________________
__________________________________________________________
Thanks for the fast responses!! I got a pic here: http://img90.imageshack.us/i/p4221405.jp... ye its green!! on the backside are chips with dates of 98' and 99'
by
Add a comment
1 Answer
Most Helpful Answer
There is no really good way to test a part based on a visual inspection. If you see any damaged, disformed, or "fried" components, then the chances are, it's bad. Sometimes, though failure can happen on a non-visual level. For example, a bad solder joint (Solder holds every component to the board, and forms the electronical connection) which can be virtualy undetectable, or a bad intergrated circuit, such as damage to a chip that isn't visible on the outside. The best way to test anything it to plug it in. Note, if you are going to buy a case, keep in mind that each logic board has it's own specific case.
Logic Board Info (Based on date on board, with name, and nick-names)
1999 - The original powermac G4 (Graphite, "AGP Graphics", "Yikes!")
Early 2000 - See Above
Late 2000 - Powermac G4 Quicksilver (Digital Audio, Gigabit Ethernet, Quicksilver)
2001 - Powermac G4 Quicksilver (See Above)
2002, Green - Powermac G4 Quicksilver (See above, except includes LDS)
2002, Navy Blue - PowerMac G4 MDD (MDD)
2003, Navy Blue - PowerMac G4 MDD (MDD, some may have a firewire 800 port, as well as 2 firewire 400 ports)
2004, Navy Blue - PowerMac G4 MDD (MDD, Last PowerMac G4 Produced)
Score 1
Add a comment
Add your answer
steve will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 17
All Time: 5,531
