Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2397 Questions View all
Is this aerosol electrical cleaner safe to use on iPhone logic board?
The battery life of my iphone 4 has become terrible after fixing screen, my thoughts are that I must have touched a connection and left grease on it as battery life is good in airplane mode.
I bought this today, is that okay to spray directly onto connections then remove with a swab?
Also, what connections do you suggest I clean?
Thanks!!!
Link to picture of spray: http://i.imgur.com/2X1enye.jpg?1
Score -1
1 Comment
Without knowing the ingredients its hard to say. Some of these sprays have toluene which can damage plastics, some have oil which can cause odd problems. What I do is use a hand pump sprayer which I load with 90% isopropyl alcohol. Then I know what I'm using, and I don't use it for anything else.
by
Add a comment
1 Answer
Chosen Solution
Ben, anytime you use any of those sprays you are running the risk of creating a short circuit with it. I would suggest that you clean the board with a high grade (90%+) of isopropyl alcohol.
Score 2
Add a comment
Add your answer
Ben will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 2,254
