Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Questions View all
Hard Drive replacement? Have new hard drive.
Have new hard drive for my Macbook Pro..The old drive has been replaced without my knowledge by my ex who hacks computers for a living....Can I just put new drive in with out the use of the corrupted old drive?
Here are the parts I order from ifixit...
1. 750 GB 7200 RPM 2.5 " Hard Drive / Seagate
2. 750 GB 7200 RPM Seagate Hard Drive
3. PC3-8500 (2) 4GB RAM Chip/New
Need help with this don't want the ex on my computer any more....Thanks Kim Lim
Score -1
17 Comments
Thank you so much....Have new HD in and I have OS-X Install gray disk and Applications Install gray disk...I did all steps to install as new and at one point I did get the a file with a question mark and that was it . I went to next step in my everything Mac book manual and it had me restart holding down c key and power, now I have a Lock asking for password.... I do not have the password not sure what to do now...:( I also have all my other disk that came with my Mac just can't seem to get it up and running...I did buy two HD's .I thought if I messed up one no biggie I have a back up.... NEED YOUR HELP....:) Thank Kim Lim
by
You have a hardware password set on your system. You'll need to remove one on the memory modules to get it to reset. Give that a try. Once reset put the memory module back in.
by
Don't open the other drive as you should be able to return it.
by
I have flashing file with ?....
by
Thats a good thing!! You have a blank HD that now needs the OS installed. Now put the grey Apple logo'ed CD/DVD into your optical drive and restart it. The system will then boot up using the OS on the CD/DVD and you should be greeted with a little welcome movie and then you will be asked some Q's to then install the OS.
by
Show 12 more comments
Add a comment
1 Answer
Chosen Solution
Yes you can put a new HD in your system without having your old HD. You may need to buy a new copy of OS-X if you don't have the grey recovery CD/DVD that came with the system.
If you don't you'll need to order them from Apple. One more option here is after you install your HD go to an Apple Store and see if they are willing to help you re-install the OS from their servers (you'll need to make an appointment with them and they may charge you a small fee). But you need to get the system functional (boots up with a question mark)
I noted you have listed two HD's on your list is that a typo? You only need one. Depending on the model of HD you bought you may need to alter the SATA I/O speed most of the newer HD's support the newer SATA-III spec (6Gb/s) while your system only has a SATA-II (3Gb/s) interface. Some have a jumper to lower the speed down to SATA-I spec (1.5Gb/s) you may need to do that here. Make sure you check the EFI firmware as well review this Apple TN EFI & SMC firmware updates
Follow the iFixIt guide on replacing your HD iFixIt HD replacement guide on how to do it.
As to the applications you might have had on your old drive. After you get your new HD and the OS installed. We can review what you could try doing to recover some of these without putting your system at risk. Also we can go over how to protect your system. But for now lets focus on the HD replacement.
Add a comment
Add your answer
kimlim80088 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,556
