What do I do if I accidently washed my iPod?
I forgot that my iPod was in my pants' pocket, and I threw my pants in the washer. The iPod is washed and I have left it in a bowl of rice. What else can I do or should I have done?
Add a comment
1 Answer
Chosen Solution
Jarren, the same treatment as other water damaged iDevices would be appropriate. I suggest that you clean it. Rice and other desiccant's are a great first aid, but they will not prevent corrosion. Disassemble your iPod using this guide , and clean every part, connector and cable with 90%+ isopropyl alcohol. Make sure that you remove any EMI shield. Use a soft brush to clean the connectors and cable ends properly. Check for missing or burned components. Once it is cleaned, replace the battery. After that, reassemble your iPod and re-evaluate. Hope this helps, good luck
Score 1
Add a comment
Add your answer
Jarren will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 21
All Time: 1,164
