Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
Why aren't my side sound buttons working?
The silence button is not on, my change with buttons tab is set to on. Also, I can hear incoming calls and talk to people on speaker phone and regular volume. However, I can't hear any music, videos, etc. even when I go to change the volume on the now playing screen in "Music" the slide tab won't even show up. When I press the side buttons sometimes, the ringer volume shows up and the small squares showing the volume don't pop up. What should I do? I've only had my iPhone for 3 1/4 months.
Score 2
Add a comment
Most Helpful Answer
Ciaran Change the dock connector as this has the mic attached to it
And Rachel changing the dock will also fix your problems also
Score 1
Add a comment
It sounds like your phone thinks it's connected to a sound dock. Possibly some corrosion has built up on the bottom pins in the dock connector. You can get some Isopropyl Alcohol 91% and try to clean it out with a tooth brush. Be gentle as the pins can easily be damaged. Give that a try as it might be the solution you need.
Add a comment
When im talking to someone on the phone i can hear them perfect but they cant hear me at all, if i put the caller on loud speaker they can hear me but not off loud speaker . Can someone please tell me how to fix this?
Add a comment
Add your answer
Rachel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 3,473
