Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Questions View all
White Lines on iPod Touch 4th Gen LCD
I have replaced the LCD/Digitizer on this iPod, and when I plug the power in (or turn it on), if I leave the screen kind of there, but not pushed down all the way, it seems to work great. Picture is good, touch works, etc.
However, when I go to press the screen down (i'm test fitting before removing the cover from the adhesive), I start to get horizontal white lines. Once I see them, I stop immediately, because I don't want to damage anything.
What could be the problem? Could it be that I don't have the LCD cable plugged back in correctly/all the way? Is the LCD cable the one that plugs from the top of the logic board, or the one on the botttom?
Thanks
Add a comment
Chosen Solution
Sounds like you have bought a bad LCD . The LCD is the one that plug in on top of the logic board
Score 1
1 Comment:
Thanks for the response. It turned out to be that I did not have the LCD plug seated correctly. Once I got that seated correctly, it worked.
by
Add a comment
My iPod has horizontal lines on it and I can't see my screen properly
Add a comment
Add your answer
Bobby will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 3
All Time: 894
