2.26 or 2.4 GHz / White plastic unibody enclosure
How to replace the LCD lid Back Cover?
What steps need to be followed to replace the Unibody A1342 LCD lid Back Cover? There are a series of cracks on the lid cover near the hinges and in the middle of the cover. I have a new lid and I assume I will need to follow the LCD panel replacement guide. But there is the camera, etc. What else is in there?
Score -1
Add a comment
Chosen Solution
Just follow the steps to replace the display assembly and the display cable , then re-assemble into the new lid instead of the old lid! :-)
MacBook Unibody Model A1342 Display Replacement
MacBook Unibody Model A1342 Display Data/Camera Cable Replacement
MacBook Unibody Model A1342 Display Image
Guide
Difficulty:
Difficult
15 - 45 minutes
MacBook Unibody Model A1342 Display Data/Camera Cable Image
Guide
Difficulty:
Difficult
Score 1
Add a comment
Hi Henry !
The best thing you could do here would be following one of these two Teardowns, which show you how to disassemblate your whole MacBook.
Hoping to have helped you !
Don't forget to give us some feedback :)
Vincent
MacBook Unibody Model A1342 Mid 2010 Teardown
MacBook Unibody Model A1342 Teardown
MacBook Unibody Model A1342 Image
Guide
Difficulty:
Moderate
Guide
Difficulty:
Moderate
2 Comments:
Thanks, Vincent. I had actually already viewed these two excellent tear-downs only to find that they do not tear into the LCD display lid; and so I posted the question about what else is contained in the old lid that will need to be moved to the replacement that I bought. The LCD replacement guide is pretty close to the mark, but it looks as if the antennae and the camera remain untouched.
The cracks in the lid hinge is a very commonly reported problem, so I feel certain that some daring soul in this community has replaced the back cover on a white unibody. I would be honored to benefit from that experience.
Thanks in advance for replying.
by
I think I may have found the path to success! There is a Guide here called "Rear LCD Bezel removal." It looks to me as if that series has all the parts I could anticipate needing to move to the new LCD back cover. I will report back after I receive the replacement part to be sure that the frame is indeed included in the back cover.
by
Add a comment
Add your answer
Henry Gardiner will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 2,875
