Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
No GPS signal since some weeks.
Hi!
I do not receive any GPS signal on my 3GS since a month or more.
I'm on the 05.13.04 baseband and iOS 5.1.1
Perhaps reinstalling the OS may help ?
Perhaps hardware damaged ?
I broke the n°3 connexion. The sound works, but not the presence detection. Is there a link between n°3 connexion and the GPS ?
Thanks helping me ;)
Score -1
6 Comments
Bonjour Vincent,
Peut-on poursuivre en français ? Je vais tenter une réstauration de l'OS.
by
Mon email : Vincent.monteil@neticiens.fr
N'hésite pas !
by
number 3 cable is for the earpice speaker and proximity sensor, it is not related to the GPS.
by
Thanks for that.
by
J'ai fais une restauration sans succès. Toujours pas de signal (ou très rarement). Est-ce que ça peut venir de l'antenne ? J'ai vérifié le branchement.Tout m'a l'air normal. Je ne sais pas exactement si ça a commencé après avoir démonté mon iPhone pour changer le bouton power (donc dépose de la carte-mère). Mais tout semble bien rebranché.
by
Show 1 more comment
Add a comment
Chosen Solution
You're right ! It can be a software problem. You may backup your device DATA and restore it with iTunes. Then tell us what happens.
Check that location service is active.
Do you have photos of your broken N°3 connexion ?
Add a comment
Hi !
Here are the pictures of the n°3 damaged connexion.
The connexion can move up on the left side (iPhone normally in front of you). It's not really fixed yet on the motherboard on this side. The second contact is not at his place.
Thank you helping me.
Other question: what is the round "connector" on the back top right of the logic board ? Nothing on it on mine.
2 Comments:
The round "connector " is an antenna connector....
by
GPS antenna ?
by
Add a comment
Finaly I replaced the WIFI/GPS antenna. It works well.
Add a comment
Add your answer
bmael will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 419
