Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
549 Questions View all
Question Closed
How much RAM can I install?
Hi.
I have and iMac 20-inch early 2008 MB 324E/A
Intel Core Duo ("Penryn") 2.66GHz
I use PC-26400 (800MHz) DDR2 RAM SO-DIMM.
I used to have 2GB. According to some info I got, the maximum amount of RAM I could install was 4GB. So I did.
However, I recently used the Mactracker app, and under the "Maximum RAM" info, it says: 6.0GB (Actual) 4.0GB (Apple)
What does this mean? That I can install 6GB?
If so, how? Because I only have 2 RAM slots. That would mean that one must have a 2GB DIMM, and the other one a 6GB? Or use only one slot with one 6GB DIMM?
I am really interested in knowing this, as I use RAM-intensive applications: Photoshop, Illustrator, Final Cut, etc.
Thank you
Add a comment
1 Answer
Chosen Solution
No you would have one 2 GB and one 4 GB sticks of ram. Good luck Ralph
2 Comments:
You are correct--Mac tracker states 6 GB is the max. Ralph
by
So should I trust Mac tracker? If I install 6GB my Mac would recognize it properly?
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 3,175
