PC laptop by Dell with a 15.4" display. Succeeded the Inspiron 1520.
70 Questions View all
Unable to detect Hard Disc.
System is unable to detect Hard Disc. It was working fine last night and when started today, its showing message that Unable to find Hard Disc. I am worried for loss of data.
Please suggest me a solution as soon as possible.
Score -1
Add a comment
Most Helpful Answer
Amit Lal, it is possible that your hard drive has failed or just the boot record. Set you computer BIOS to boot from an optical drive. Then use a copy of a Linux Live CD and see if you can boot from that CD. If you can, scan the hard drive and if you gain access to it, copy all the vital file to a USB drive. After that you could try to re-install the Windows OS. If your drive is not accessible, you may have to replace it and try to recover your data through some recovery software. I prefer Puppy Linux and you can do a quick search for it and copy it. Hope this helps, good luck.
Score 1
2 Comments:
I checked the hard disc in another laptop too, but it is not detecting. so could you tell me any way to recover the data. As I have important official data inside the hard disc.
by
first you need to see if you can still access the drive. Use your computer, but change the BIOS. Boot from CD and see if you have access to your drive. Use either a LINUX or a copy of Hiren's Boot CD. You will have to have access to the drive in order to copy files to a different medium, i.e. USB drive.
by
Add a comment
Hi,
If you have tried testing it on other system and it is not getting detected then it must have be electronically damaged the media card which makes it next to non recoverable unless you find exact media card for disk.
Good Luck.
Add a comment
Add your answer
Amit Lal will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 349
