Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
794 Questions View all
Where can I find TDK 6t213hf
I have current across logic board and megasafe connector lights up green.
I have seen the TDK chip is damaged and one another chip too. I would like to know where i can find this chip to buy so that i can replace it.
Thanks
adnan
Update
Try this link Chip. This is the only place i can find it. Let me know if that works.
4 Comments
Hi Adnan !
How about your macbook , have you fixed it yet ? My problem seem to be like yours, my Macbook did not charge battery but it could turn on by using adapter connecting directly.
It s very hard to find replacement chip TDK. :(
by
Duong
I was able to replace the TDK Chip and my Macbook Pro worked perfect after that. It was not easy, but in the end with lots of patience i was able to finally replace it.
Since then, i have no problems with my Macbook pro.
by
Hi, Could you pls tell me where you get new TDK chip, i am very exhausting to search it !
And will it be compatible with my Macbook 13'' late 2010. thank you very much !
by
HI,
And what was the other chip which was damaged?
by
Add a comment
Chosen Solution
Adnan, you could get it from places like this Also, check on here and contact those companies. Remember that it is not an IC but a transformer ;-)
Score 2
3 Comments:
Can we confirm that that TDK magnetic belongs to the charging system? The Mac Mini also has the same chip and it has no battery. Seems like it may belong to the Ethernet circuit?
by
Stephen Bacica, you are right. It is part of the ethernet circuitry; at least on a MacBook Pro
by
Dam! Was hoping to be wrong. So it sounds to me like he guy above does not have a fix for the no charge 0% battery problem.
by
Add a comment
One might think that this issue should be already solved, but, can anyone help me????
I have a pro 2011. The battery stoped to be charged and the computer stared to run too slow.
I changed battery and the charger, but no improvement came out. The computer started to shut down aleatory. I checked the fan and cleaned it. Oh! It got to run normally. But the issue of battery charging still remained. I changed the DC in board, but the problem still persist. No light gets on on Magsafe. The computer does not work if I take off the battery.My question is if it is possible that if I replace the TDK 6T213HF the battery would charge again.
Adnan says that he got everything solved by doing this, butoldturkey03 says that this transformer (TDK 6T213HF) is used by ethernet circuit and not to shift the computer supply...
Can anybody help me?
2 Comments:
you can check this link on youtube or search for Louis Rossmann channel for macbook family repairs.
https://www.youtube.com/watch?v=FGYrykiL...
by
Thank you Adnan. Did you really get your computer fixed after changing the TDK 6T213HF?
Kind regards
by
Add a comment
Add your answer
Adnan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 3,531
