resolution out of range
my pc got the problem of screen resolution and it is showing out of range with black screen how can i solve it plz any 1 answer it
If the display is showing you this message then the signal the PC is sending to your display is not one of the supported modes for the display.
To fix this you'll need to reconnect the old display (if you exchanged it out) so you can see the desktop and then go into the Display control panel and set the settings for what your new display is able to support. If you can't put back the old display you'll need to boot the system up in Safe Mode heres a good link on how to get to it under the different versions of Windows Safe Mode, Once there go into your display control panel and alter the settings as needed. You may want to lookup your displays resolution choices on the manufactures web site if you can't find the documentation for it.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 13
All Time: 17,582
1 Comment
Did you get a new monitor? I.E. bigger size or smaller? Have you checked all of the cables going into the desktop itself? If you have a graphics card, will it support your current resolution?
by JSmith Share
