Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
blue coil weak wifi iPhone 4 GSM
i used a magnification lens to look at the blue coil. The coil looks like its still good, no sign of being broken or burned. But my wifi is still weak, my cellular signal is normal. The wifi antenna cover has the little clip. How can i solve this?
does the jumper cable work for my problem? if so some pictures would be nice. thanks
Score -1
Add a comment
1 Answer
Chosen Solution
Are you using the long screw on the top of emu shield and has it got the little metal clip under that screw...
2 Comments:
Yes the screw is there and screwed on hand tight with the metal clip touching the bronze dot on the mother. Any other ideas?
by
You see the bronze clip at the top of the motherboard is it touching the frame when the motherboard is attached in? If not bend it slightly so it is be careful it's easy broke!
by
Add a comment
Add your answer
nathanliang007 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 158
