The second iteration of Samsung Galaxy Tab tablet computers with a 7.0-inch screen. Model numbers: GT-P3105, GT-P3100, and GT-P3105.
Water problem help fix?
my tablet has fallen in water, I immediately took it out and left it, it start then restarts every one minute, one guy told me to leave it for 1 week nd then it will start working, is it true?
Score -1
1 Comment
i have same problem :(
by
Add a comment
1 Answer
Chosen Solution
Joe, "to leave it for 1 week" will only ensure that you have a more corroded logic board. First I would no longer try to charge the device or try to turn it on. I suggest that you disassemble your device completely. Then clean each and every part with some high grade (90%+) isopropyl alcohol, this includes all the cable connectors. Once it is cleaned, replace the battery, reassemble your device and re-evaluate. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
Joe will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 684
