Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Questions View all
My iPhone says its disabled
My Iphone 4 has on the screen: iphone is disabled please try again in 22,652,900 minutes.
I have tried to restore it with iTunes and even reset it but it then asks me for the passcode to be entered in on the device and I cant because when I go to unlock the screen it only goes to emergency calls only it doesn't give me any options to enter a passcode and I don't know what the passcode is as I never put one on there or if I did I don't know what it is, Ive never had to enter an unlock code when I turn the phone on so I am unsure of this. PLEASE HELP
Score 13
1 Comment
my iphone 4s sim not valid activat
by
Add a comment
Most Helpful Answer
1. Disconnect the USB cable from the device, but leave the other end of the cable connected to your computer's USB port.
2. Turn off the device: Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the device to turn off.
3. While pressing and holding the Home button, reconnect the USB cable to the device. The device should turn on.
4. Continue holding the Home button until you see the "Connect to iTunes" screen. When this screen appears, release the Home button.
5. iTunes should alert you that it has detected a device in recovery mode. Click OK, and then click Restore to restore the device.
http://support.apple.com/kb/HT1212
Score 4
1 Comment:
i have done this several times but after doing so and after all the process done it will still show iphone is disabled.
by
Add a comment
i have a same problem but i cant repairing plzz being helpful me thanks a lot for answer me
Score 1
Add a comment
This really helped thanks
Add a comment
Step-1: Get another accessible iPhone and go to the App Store. Search and download My iPhone app.
Step-2:  After you finish the installation of the app, you can run it and log in with your iCloud account and password.
Step-3:  Next, you will see all iOS devices which share the same iCloud account. You need to find the disabled iPhone from the list and tap it.
Step-4: Then tap on Actions at the bottom of the iPhone screen. After that, you are offered three options. Tap Erase iPhone and then you will get the disabled iPhone erased. Of course, the locked screen is removed from the iPhone.
ghd sports
Add a comment
Very informative. Thanks for the tips.
Betting Experts
Add a comment
Really Helped. Thanks!
Melbet
Add a comment
I recently had the opportunity to explore the repairability of the iPhone 14, and I must say, I'm thoroughly impressed with its design and construction. In an era where electronic devices often seem more disposable than fixable, the iPhone 14 stands out as a shining example of a device built with repair in mind.
From the moment I began disassembling the iPhone 14 https://baccarat.team/mobile/ios/, it was evident that Apple has made significant strides in making repairs more accessible. The use of modular components and connectors not only simplifies the process but also reduces the need for specialized tools. This is a welcome departure from some of the previous models that seemed intentionally complex to discourage DIY repairs.
The adhesive choices also deserve commendation. The strategic use of strong adhesives in certain areas ensures a secure fit, while still allowing for careful detachment during repairs. Additionally, the design of the device's interior layout is remarkably thoughtful, with cable routing that minimizes stress during reassembly.
One standout feature is the comprehensive documentation provided by Apple. The detailed repair guides, along with step-by-step videos, empower even novice technicians to undertake repairs confidently. This user-friendly approach sets a new standard for the industry and ensures that repair resources are not limited to professional technicians alone.
Add a comment
Add your answer
Kelly will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 17
All Time: 14,313
