battery replacement for iPhone 4 8gb
what will happen if i replace my 8gb battery with a 16 gb battery?
jess, that will be fine. The battery is the same regardless of what capacity phone you have. Hope this helps, good luck.
Thanks. and will the iphone storage change to an 16 gb instead of 8gb?
no, it will not. The battery supplies the power that your phone needs to function. The storage capacity is pending on the hard ware (memory IC's) on your logic board. Thank you for accepting my answer.
ok, and last question sorry. will the battery last longer?
do u suggest just to get a 8gb battery?
The power usage of the phone is what will deplete the battery, regardless of storage capacity. The more you use your phone, the more you do with it, the quicker it depletes. So get a battery that matches the one you are going to replace.
thank you so much!
Jess instale la nueva batería pero no carga que puede ser es para iphone 4 8GB pero la batería para 16GB
Jess instale la nueva batería para iphone 4 8GB pero para 16GB y cuando quiero cargar no carga
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 892
