Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Questions View all
iPod is locked and says try again in 22,353,345 min.
my ipod 4th gen is locked and i am computer illiterate. dont even know how it got the lock put on it except my little brother messed with it while i was at work. i am upset none the less cause i dont know what has happened. i set it up on my moms comp. so i dont have access to it someone please help
Score -1
Add a comment
1 Answer
Chosen Solution
Rpbert Miller, here is what apple says :"
You may be able to reset the passcode by restoring the device.
Connect the device to the computer with which you normally sync and open iTunes.
Note: If iTunes prompts you to enter the passcode, try another computer that you have synced with. Otherwise, go to "If you have never synced your device with iTunes", below.
Right-click the device in the left column and select Back up.
When the backup is complete, select Restore.
When finished, restore from your most recent backup.
When finished, restore from your most recent backup."
If you do not have access to the computer you normally use to sync, follow these instructions.
Score 2
Add a comment
Add your answer
Robert Miller will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 105
