Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
iPhone still thinks it's in headphone mode after replacement part
I replaced headphone jack successfully but my phone still thinks it's in headphone mode. When I connect the headphones the sound come out through them. When I unplug them the iPhone still thinks the headphones are there.
I test this logic Board in two iPhones and the same error, so the problem is in the logic I guess Any ideas?
UPdate: the iPhone is always in headphone mode, even if I plug or unplug headphones (originals)
Score 1
Add a comment
Chosen Solution
I think there is a problem with the detection circuitry on the logic board. You would have to get another logic board to correct this problem.
1 Comment:
Yes your are right. The problem is the logicboard.
by
Add a comment
Your iPhone is only made for use with an iPhone Headphones which if compared to a Standard Headphone jack are different.
Use the original headphones and plug them into your H/P jack and unplug.
This is a common problem only caused by use of standard headphones.
The iPhone H/P jack has 3 sections, left, right and mic.
You will see on the jack 3 sections.
If you are going to use a regular headphones. you need an adapter.
Score -1
1 Comment:
The headphones used was the original ones.
by
Add a comment
Add your answer
Flavio will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 7
All Time: 1,851
