Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
799 Questions View all
How do I get past the Apple logo screen?
I successfully repositioned the center button's rubber pad thinking that it would solve my problem. However, the Apple logo appears on the screen and will only go away momentarily when I do a reset.
It won't go into disk mode and won't go beyond the apple. I hear no clicking or whirring either. I've opened it back up removed and reinserted the hard drive connector as instructed on my original button question post but the Apple logo remains constant, taunting me. This last time, the battery was dead when I put it back together, but it knew enough to put a message on the screen of 'please wait, very low battery' so is that a hopeful sign of something working? There are so many parts and I'm so clueless on diagnosis that I don't want to try (buy) a bunch of used parts only to discover that the thing is unfixable. May as well buy a brand new one to have something work for sure in the end.
Score -1
Add a comment
1 Answer
Chosen Solution
Lisa, the very first thing you want to try is to run a diagnostic check on your iPod. This site shows it very well and will also explain what those test mean. Right now it appears as if your iPod does not access its firmware. This could be a logic board issue as well as a hard drive problem. The diagnostics will tell you more. Hope this helps, good luck
Score 1
1 Comment:
Sorry, I said test mode but meant diagnostic mode. Won't go anywhere else but a few seconds blank with a reset, then back to the logo. I don't hear any whirring or clicking in this whole process. Then, when the battery was dead, it was smart enough to give me a low battery message before going back to the Apple logo once given enough juice. Sigh.
by
Add a comment
Add your answer
Lisa will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 216
