Why won't my iPod connect to my mac?
I had the motherboard replaced yesterday but now it wont connect at all to my mac. Tried every usb port and it won't even show up in disk utility. Plugged it into a wall socket and it charges as well as using multiple cables
Score -1
Add a comment
1 Answer
Chosen Solution
joberteugenio, if it does charge on an AC charger but not your USB port could be related to a bad battery (Your AC adapter supplied a higher amperage than your USB ) or a bad dock connector (since you already changed the cables and the USB ports on your computer) I would double check with the place that replaced your logic board to make sure this is not something related to the workmanship. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
joberteugenio will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 170
