Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2397 Questions View all
iPhone 4 has no sound?
My iphone 4 has no sound coming out of loud speaker. The earpiece works, and the volume bar show also the loudspeaker itself is working as it works with other logic board. What could the problem be on the logic board thanks
Score -1
2 Comments
akshay patel, this could be caused by a malfunctioning headphone jack. If it erroneously sense that headphones are attached, it may open the circuit to the speaker. Do your headphones work?
by
Hi oldturkey, all the flex and jack are working as it is a test phone that so the fault will be with the logic board, wifi and all that works and the headphone also works the mic is working it only loudspeaker thats not.
by
Add a comment
Chosen Solution
Try these tricks as they have worked for most people
http://doubis.blogspot.fr/2011/09/no-sou...
http://iphonenosound.com
Add a comment
ur internal sound board might be destroyed, check ur mute button, go into setting, blow into ur headphone jack, if this doesnt work then go to apple store
1 Comment:
@Ashton , which board would that be?
by
Add a comment
Add your answer
akshay patel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 7,105
