battery not charging, green light on (works only with) power adaptor
MacBook pro shut down suddenly while on battery, could not (re)start. I tried SMC but no results. The macbook will not work on battery, as soon as I take the adaptor it shuts down.
I send a coconutBattery reading and these are the specs:
Battery Information:
Model Information:
Manufacturer: Sony
Device name: ASMB014
Pack Lot Code: 0000
PCB Lot Code: 0000
Firmware Version: a41b
Hardware Revision: 0000
Cell Revision: 0000
Charge Information:
Charge remaining (mAh): 3593
Fully charged: No
Charging: No
Full charge capacity (mAh): 5188
Health Information:
Cycle count: 652
Condition: Normal
Battery Installed: Yes
Amperage (mA): 0
Voltage (mV): 11757
System Power Settings:
AC Power:
System Sleep Timer (Minutes): 10
Disk Sleep Timer (Minutes): 10
Display Sleep Timer (Minutes): 10
Automatic Restart On Power Loss: No
Wake On AC Change: No
Wake On Clamshell Open: Yes
Wake On LAN: No
Current Power Source: Yes
Display Sleep Uses Dim: Yes
Battery Power:
Display Sleep Timer (Minutes): 2
Reduce Brightness: Yes
Hardware Configuration:
UPS Installed: No
AC Charger Information:
Connected: Yes
Wattage (W): 85
Revision: 0x0000
Family: 0x00ba
Serial Number: 0x00559f4b
Charging: No
Will be grateful for any advice,
Carlos
Score 1
Add a comment
1 Answer
Chosen Solution
So you need a new battery (any battery of that vintage that has more than 300 cycles is on borrowed time) should a new batter not charge then you'll need a new - DC in board.
Remember to return and mark accepted the answer that best solves your problem.
Score 3
1 Comment:
Thank you machead3, indeed, looks like a new battery coming this way...
by
Add a comment
Add your answer
carlos will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 742
