Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
Question Closed
Display works perfect, but glass is broken - which parts are needed?
I would like to repair my broken display. It works perfect. Everything is okay only the glass has a crack. Which parts do I need? Only the display or also the frame?
Best
Dalberg0
Add a comment
Chosen Solution
It sounds like you only need to replace the digitiser. This is stuck to the LCD and requires some skill to seperate and stick the new one on. Be sure to wear eye protection when removing the cracked one.
Here's the instructions : iPhone 3G Front Panel Replacement
Add a comment
Also take care with the ribbon cable attachment of the digitizer to the main PCB. If you damage whee the digitizer attached to the main PCB, you can just stop, as it's all over.
I've seen iPhones like that show physical damage on the inside. Once the digitizer was out, the dock connector *fell* out. The impact that shattered the glass, broke all the solder joints of the dock connector. The bizarre thing was the dock connector worked prior to disassembly, as it was sandwiched in, until we took the digitizer out.
Good Luck!
Add a comment
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 689
