Repair guides and troubleshooting for HP Pavilion dv7 laptops, manufactured by Hewlett-Packard starting in 2008, and featuring a 17.3" diagonal display.
How can I replace the flex?
The computers boots up. However, the screen turns on and off rapidly or doesn't turn on at all. The problem is independent of the position of the screen.
EDIT: Using a flashlight I realised that you can barely se the screen. So the problem is the backlight.
Score -1
Add a comment
Chosen Solution
simon, exactly what flex are you trying to replace? the reason for not having a backlight could be a bad inverter, a bad LCD, a bad Lid swithc or even a failed backlight circuit (common failure on this model) it is under the right side hinge. "However, the screen turns on and off rapidly or doesn't turn on at all" sounds more like a broken backlight cable or a failing switch.
Score 1
Add a comment
Most Helpful Answer
From what you are describing it is possible the flex cable is damaged as it carries power to the inverter for the back-light however it could also be a faulty inverter board.
The cable and inverter can be purchased for around $30 so perhaps just replacing both may be the best approach.
Inverter replacement video
Score 1
Add a comment
Add your answer
simon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 3,323
