Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
Why is the screen white after a new LCD replacement?
Hello,
So I bought an iPhone from this guy, a really bad choice because the phone was old. But after a few months it started having lines (blue and white) up and down the screen. The phone can still operate if you remember where everything is, but obviously you can't see the screen. So someone told me to replace the LCD, which i did. I did everything without any issues, following a video tutorial. After installing I turned the phone on and it showed the apple, then it went to the white screen. I tried reseting it and what not still the same issue. Also, when you plug it in to the charger you can see the screen, once you slide the unlock button it goes back to white and the only way to get rid of it is to put it to sleep and then turn it back on again.
I would really appreciate any feedback on this!
Thanks!
Score -1
1 Comment
I have already done a hard reset. and nothing changed, the screen still flickers then goes white
by
Add a comment
Chosen Solution
Have a read of THIS thread I may assist you
Score 1
Add a comment
try a hard reset
Add a comment
Add your answer
Lera will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 106
