Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Questions View all
Powers on, functions normally, no power button
I repaired a cracked glass and everything the ipod functions normally, except the LCD display and the power button. I can use the home button and the touch screen, but the display is so dim I have to hold it in the light just to see it. Also all the color is negative. The volume buttons work so the power cable is still intact.
Score -1
Add a comment
Chosen Solution
My guess is that you've partially torn the power button flex.(happened to me, so I know it's possible to break the power button only) as for the LCD, the LCD data flex or the connector maybe loose or damaged.
Add a comment
No sure on the power button but it seems like you've blown the back light!
Add a comment
Add your answer
Travis Dingeman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 73
