Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2397 Questions View all
On reassembly, my touchscreen doesnt work everywhere, only the sides
Hi
The touchscreen has a weird behaviour. This started after I replaced the home button on iP4. On starting the phone, I noticed that the screen doesnt have touchscreen towards the center of the screen only on both the sides (longer edges).
Currently Im not sure what the issue is fully, Im thinking maybe the digitizer cable got damaged, though Im not sure.
I also think that the front facing camera is not working. When I enable that from the lockscreen camera, I notice that the it gets stuck and flickering.
Weird touchscreen behaviour after home button replacement
Any thoughts.
Regards
Antony
Score -1
Add a comment
1 Answer
Chosen Solution
Antony FM, sounds like either a pinched or tore ribbon cable, or a broken digitizer. Of course, you do want to double check your work, make sure the connectors are properly seated. It has been my experience that if the digitizer is unresponsive on certain areas, it has failed and you will have to replace the assembly. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
Antony FM will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 611
