A 4GB 3.6" Touch Video MP3 Player by Sylvania.
Why won't player turn on?
I have tried over and over again to turn my player on. I have tried charging it several times and have even tried the reset button, but it will not come on. It was working fine, then I started downloading some more music when it shut off and would not turn back on. My laptop recognizes that it is pluged up. I only have a USB cable to charge it and I have even tried three different USB ports on my laptop. What is the cause and fix for this problem?
Score 1
Add a comment
Chosen Solution
henryr79, it does sound like a battery failure. If it has discharged to below its threshold it will no longer accept a charge or hold a charge. I would start with that. Follow this teardown to change your battery and re-evaluate. hope this helps, good luck.
Score 2
2 Comments:
What does a battery cost and where can one be bought?
by
Once you have it apart, there should be a number on the battery. Use that to do a search according to your location.
by
Add a comment
It was not working and how to fix it.
1 Comment:
Um... what are you talking about???
by
Add a comment
My sony walkman wont turn on
Add a comment
Add your answer
henryr79 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 2,801
