Released on June 23, 1996, Model NUS-001, 64-bit gaming console
114 Questions View all
Why won't the TV recognize my N64?
Hi! I was feeling pretty nostalgic recently and got an N64. It worked for a few plays, but I've been trouble recently. The N64 turns on just fine, but the TV won't recognize it---it gives me a "no input" error.
I thought it might just be AV cables going bad (they were pretty old) so I replaced those, but no dice.
I did just get an expansion pack to play Majora's Mask, but it worked after that for about one play. Since then it hasn't.
I've tried different ports to make sure I have the AV cables in the proper place, and nothing appears to help. I've plugged it into TVs not connected to satellite, I've disconnected other gaming devices, I've tried everything I can think of. Does anyone have any suggestions?
i've tried it on multiple television sets, by the way, in different households.
Score 1
1 Comment
Probably logic board failure. I would recommend getting a new one.
by
Add a comment
1 Answer
Chosen Solution
Rachel, hope it has worked on the newer TV's before. Anyhow, I would suggest that you clean the cartridge slot first, follow this guide. After that, it is time to open up your console, use this guide, and check for any obvious signs of burned or loose connections. Check for broken solder contacts near the power switch and near where the power pack plugs in. If you are handy with a multimeter, I think I even have some schematics for this console. Hope that helps, good luck.
Nintendo 64 Image
Guide
How to clean the Nintendo 64 cartridge slot
Difficulty:
Very easy
5 minutes
Nintendo 64 Motherboard Image
Guide
Nintendo 64 Motherboard Replacement
Difficulty:
Easy
15 - 20 minutes
Score 2
Add a comment
Add your answer
Rachel will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 29
All Time: 7,451
