I desasemble 3g and see a short circuit
i made a spark with screw driver and now its black . when i charge it it shows battery but not charging or turn on . thanks in advance
teodorescu marius, thank you for posting the image. It appears the component that shorted out it is the battery fuse. This could of course be the reason why it does not charge ;-) Check the posted image and see if that is the part in question. The appropriate part number (Littelfuse Inc) seems to be 0435002 (http://www.littelfuse.com/data/en/Data_S...). You could place a temporary jumper across to see if it makes a difference. Do not keep the jumper on it permanently. Hope this helps, good luck.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 351
7 Comments
What component did you shorten out? Check for burned or charred component.
by oldturkey03
when i charge the iphone i reset and it open the apple but its like doesnt have batery and wont open all the way even if its plug in the charger . its still a broken component ?
by teodorescu marius
the spark was near the litle tube cilindre the one with rubber on it , just underneath him .i open just the thouchscreen and 3 cable and is spark there ...:(
Can you post a few images of your logic board and point out the part. Follow this guide to post images. Adding images to an existing answer
by oldturkey03
i post 2 images . can any1 tell me what could be . the place were the spark wass its unusual
Show 2 more comments
