Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1497 Questions View all
A piece of 'something' got into the headphones 'hole', what to do?
Hello!
I was walking on the street and wind got into me. Unlucky me, a piece of 'something', dirt, little rock, don't know, got into the headphones 'hole'.
What should I do? I tried to remove it with everything I could, it just won't leave and now I can't listen to music ..
Add a comment
1 Answer
Chosen Solution
Did you try using a drinking straw and some vacuum?
- a small pin (hold unit up so that the jack hole is facing down for a gravity assist).
If not you may have to follow a guide & dismantle to see if you can find/push/work out the debris from the inside.
Good Luck,
N.
Score 1
Add a comment
Add your answer
Paulo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 655
