Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
581 Questions View all
Replaced Trackpad now Click Doesn't work
So the glass on my old touchpad broke and I ordered an OEM trackpad to replace it. I got it all back in (reused the cable) and everything works but the click. Touch works fine, but no click.
I tried adjusting the torx screw in a bunch of different ways, no difference. So I then put in the old trackpad with broken glass. That doesn't work either, touch fine, no click.
What could I be missing? It must be some way i'm mounting it. Does the tension on the two little metal pieces that hold it in place matter? Any tips?
Score -1
1 Comment:
Can you clarify what you mean by Click here. Does the button plate depress correctly (depresses & springs back) or does the system fail to acknowledge the press of the plate? Do you get it to sense the press on one or more edges?
by
Add a comment
1 Answer
You probably need to get new screws.
2 Comments:
You think the little screws on the top of the trackpad are messed up?
by
Is your button moving or not?
by
Add a comment
Add your answer
Tim will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 234
