Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Unresponsive Power Button? Wich one now?
Hi
I've an iPhone 4 with and unresposive Power Button ?
Wich part should i replace ?
This :
http://thumbs3.ebaystatic.com/d/l225/m/m...
This :
http://images.bidorbuy.co.za/user_images...
Or just this :
http://s4f896adf14dc2.img.gostorego.com/...
Thnks
Regards
Update
I just edit the link , try now.
When the Button won't click can't it be a bracket problem ?
Score -1
Add a comment
Chosen Solution
I fixed a 'depressed' button on an iphone 4 just a couple days ago. On the cable itself, where the power button is actually located there is a black circle. That wears out over time and is generally the problem. The cable fixed my issues. Not saying it isnt the bracket, but I woud go with a cable repair first.
option 3 looks viable but a potential pain in the neck to get that put on the old cable. The new cables are somewhere between $5-$15. Not too expensive
Add a comment
You must first identify if you have a GSM or a CDMA iPhone 4. GSM=AT&T and CDMA=Verizon
this top one is for AT&T and the bottom is for Verizon. The links you had. the first...just the power button bracket, already in the phone and doesn't need replaced. the second two links would not show the image. message me if you need any more help!
1 Comment:
by
Add a comment
Add your answer
Ricardo will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 492
