Repair guides and support for Olympus digital cameras.
231 Questions View all
Is there a way I can turn the Olympus E-P3 screen on/off?
One day the screen was black after i switched it on. The touch functions still works, i can take pictures touching the screen.
I can use the VF-1 optical viewfinder and it works as it should.
So everything works, except that the screen is black.
Is there a function i've missed where you can turn the screen on/off? (i've read the manual and can't find anything about this)
Can it be a loose cable as the touch is working, but not the image?
Score -1
Add a comment
1 Answer
Chosen Solution
umagon1337, it does not appears as if the LCD can be turned off on purpose. The E-P3 uses two separate ribbon cables on the display, so it is possible that you are having trouble with the LCD ribbon while the digitizer still works. At this point I suggest that you disassemble your camera and check for any loose connection. Take a look at the LCD, it appears as if you are needing a new one.
Score 1
2 Comments:
Thank you for your answer. I guess i will buy the right tools and open it up as you say and hope it is just the one ribbon cable.
by
Sounds like a good plan, I hope it will work out for you. Thank you for accepting my answer.
by
Add a comment
Add your answer
umagon1337 will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 8
All Time: 274
